Emulsion tube prices and reputable bike shops in general
Omegaman
Re: Emulsion tube prices and reputable bike shops in general
Post by Omegaman » Wed Mar 19, 2008 10:57 pm
the emulsion tubes worked out at £8 sterling each
was the Dynokit that cost about £90 that out it up which you dont have to buy -i just decided why not ha ha
Its all fun and games till someone gets poked in the eye.
Omegaman
Post by Omegaman » Wed Mar 19, 2008 10:58 pm
so adjusting the top and botton yoke ?
Post by youngy » Wed Mar 19, 2008 11:00 pm
I find it easiest to remove the clip-ons, as they get in the way of the top yoke pinch bolts. Then undo the bolts on one leg, adjust the height, tighten, and do the same on the other leg
Omegaman
Post by Omegaman » Wed Mar 19, 2008 11:03 pm
Thanks you two just been looking at a picture of my bike yeah i catch the idea looks simple enough cheers
hope it makes all the difference everyone suggests
kookimonsta
Post by kookimonsta » Thu Mar 20, 2008 12:48 am
one of my suppliers has a trx dynojet kit on clearence so i can supply one cheaper the rrp, if your interested pm me. i can also get genuine emultion tubes.
TRiXy
Post by TRiXy » Thu Mar 20, 2008 6:23 am
what's this dynojet kit consist of? i've heard of plenty of people selling them but i'm not really sure what they are to justify the $$ is it just carby jets? or is there more to it?
Omegaman.... does toymods mean anything to you???
Current Rides:
Post by HansJ » Thu Mar 20, 2008 10:09 am
From what I've heard, the DynoJet kits are crap, but I have no experience myself. They are supposed to be optimized for a particular motorcycle model. For this, they charge more than standard parts, which, if it worked would be OK... But people claim they wear out really fast. FactoryPro has been mentioned as a good alternative, same idea, but better material choice. My own tip would be to call Steve at http://www.topham.de, speaks English (probably an ex-pat), with good Mikuni/TRX knowledge, and good service for even lower prices than Kedo. He knows what You'll need!
Post by youngy » Thu Mar 20, 2008 10:20 am
TRiXy wrote:what's this dynojet kit consist of? i've heard of plenty of people selling them but i'm not really sure what they are to justify the $$ is it just carby jets? or is there more to it?
I could tell you but some people might not like me to, as it's very complicated. :joke:
But anyway................TRX DJ kit consists of a pair of needles and 3 sizes of main jet. As Hans said they're "optimised" for the model of bike - oe jetting has to meet certain emissions requirements which may cause restriction or impaired throttle response for example. The DJ kit "should" allow the carbs to work more ideally. Main jets are selected depending on air filter and exhaust combination.
I have one fitted and I think it's an improvement. Whether or not it justifies it's price tag is another matter, and may not be what you want to do.
As far as wearing out, I think that is old history. Old DJ needles were turned on a lathe - when the tool got old, ridges would appear on the needle. These ridges worked like a file on the emulsion tubes. Newer DJ needles don't suffer from this.
I used a Factory Pro kit on a previous TRX. Unfortuantely the TRX was never sold in the US, so the kit is for the TDM - Factory Pro had at that time never laid hands on a TRX. FP have different ideas about needle design to DJ. The jet sizes are different in the FP kit as it's meant for the TDM. I found the DJ kit more useful for this reason. Both kits give a fatter feel to the mid-range and better throttle response imo.
I would suggest that if you just want to sort out your running problems then you don't ned one, although if you do get one you may be pleased with the difference.
Post by HansJ » Thu Mar 20, 2008 11:11 am
That's right, let's discuss real world issues instead :lol: Gas prices, that'd be more relevant instead of fuel efficiency, or? :roll:
(And Jak, I used smilies as You insisted :twisted: )
OK, fair enough with the DJ kits, there are so many hard-to die "truths". Fact is, until properly tested, It's hard to tell which makes the biggest improvement, the DJ design or the re-jetting itself? But it's good to know that the DJ are not as crappy as I wrote, makes it less risky to test them!
steve speed
Post by steve speed » Thu Mar 20, 2008 11:13 am
jak is going to :violent1: :violent3: :whoopass: :kicknuts:
Post by Jak » Thu Mar 20, 2008 11:25 am
steve speed wrote:jak is going to :violent1: :violent3: :whoopass: :kicknuts:
Yes :kicknuts: behave :wink:
Post by HansJ » Thu Mar 20, 2008 11:49 am
:-({|= :headbang: :sex:
Omegaman
Post by Omegaman » Thu Mar 20, 2008 3:51 pm
Trixy no idea what you mean unless your stating that im buying pointless toy style mods for my rex? in which case i am yes :D
TRiXy
Post by TRiXy » Thu Mar 20, 2008 11:43 pm
well your half right... i know an "omegaman" no another forums.. toymods.net it's all about toyota modifications etc...
back on topic...
Current Rides:
