Pazzo levers for TRX?
Trixz
Re: Pazzo levers for TRX?
Post by Trixz » Fri Jun 05, 2009 1:57 pm
Wombat wrote:Nah, what I meant was, is it a straight plug in for the TRX connector to the tangs on the R6 clutch switch or do you have to buy the R6 connector loom to plug into your harness? Or can you retro fit the TRX switch onto the R6 lever?
Hey Bob,
it's been a while since I did the conversion, but I took a look at it today and must say that the connector isn't connected (to anything :| ) .
So NO straight plug in, don't know what to convert to get it done.
Post by slow codger » Fri Jun 05, 2009 2:13 pm
:? So Gerben are you saying that the connectors are different, and also does yours start in gear ????? (with clutch out)
steve speed
Post by steve speed » Fri Jun 05, 2009 3:01 pm
would that be a problem with the starter relay or is it the clutch switch ??
Wombat
Forum Marsupial
Post by Wombat » Sat Jun 06, 2009 6:55 am
Had a look today. Funnily enough the CRG R6 brake lever lever seems to fit straight on without any hassle? Will take it for a test ride soon. The TRX and the R6 clutch switches are again wildly different. The tangs on the TRX one are smaller, so they are not compatible. Probably have to get the connector wires for the switch to the block for an R6 and the cables adjusters between the two models are different sizes as well :evil: Trx cable adjusters are 8mm and 30mm long, R6 ones are 10mm and 34mm long - looks like another trip down to the wreckers #-o
I thought this was gonna be easy.
:x
steve speed
Post by steve speed » Sat Jun 06, 2009 11:25 am
a bit of soldering and some heat shrink and you should be sorted
Trixz
Post by Trixz » Sat Jun 06, 2009 6:57 pm
slow codger wrote::? So Gerben are you saying that the connectors are different, and also does yours start in gear ????? (with clutch out)
Yes and I can't say that I've noticed anything different since the conversion, so I do think it will start in gear with the clutch out. But to be sure, if I do ride tomorrow, I'll give it a try :) *and if not, I'll try on monday :wink:
Wombat
Forum Marsupial
Post by Wombat » Tue Jun 09, 2009 2:51 am
Gerben, just pulled off the connector and started the bike, and was able to select 1st gear and take off. So you were right about it not needing the switch to be connected. =D>
So all I have to get is the cable adjuster and the L/H side is done. Will put on the brake lever when I change over the TRX > R6 mc. How did you change the levers, did you undo the 6mm allen head retaining screw or did you just pull off the grip and the switch?
Trixz
Post by Trixz » Thu Jun 11, 2009 3:51 pm
Wombat wrote:Gerben, just pulled off the connector and started the bike, and was able to select 1st gear and take off. So you were right about it not needing the switch to be connected. =D>
8) OK then!
Wombat
Forum Marsupial
Post by Wombat » Sun Jun 21, 2009 8:26 am
Fitted on the bike today in all this rain :cry:
Trixz
Post by Trixz » Sun Jun 21, 2009 7:59 pm
Still it's a lot of *bling bling* there mate 8)
M.V.
Post by M.V. » Mon Dec 21, 2009 1:42 am
Hey Wombat, they look good!!!
Is that R6 levers on standard TRX perch or did you have to swap them over too?
Cheers!
Wombat
Forum Marsupial
Post by Wombat » Mon Dec 21, 2009 7:01 am
Mv,
had to swap for an R6 perch, and don't forget to get the cable adjuster with it too. All up about $30 from the wreckers. For added bling I am now looking for a CRG clutch perch $$$$$$$$$
M.V.
Post by M.V. » Tue Dec 22, 2009 2:43 am
So the brake lever just bolts up right? Only need to replace the clutch perch?
Sorry for being thick! #-o
Edit: I read your post properly, thanks for the info!!!!!
One last question though; What year R6 levers did you buy?
Cheers!
Wombat
Forum Marsupial
Post by Wombat » Tue Dec 22, 2009 5:51 am
yeah the std TRX brake mc seemed to work - though I do have an '03 R6 mc waiting in the wings to be fitted, to give better feel, '03 clutch perch too.
