new TRX - big smile & bad pain!!
Re: new TRX - big smile & bad pain!!
Post by Mincehead » Sun May 03, 2009 7:53 pm
Sounds like you wallet users have far too much wad! :wink:
I don`t like wallets,never use them myself.I don`t have much money to put in them anyway,it gets spent on bikes.
Wombat
Forum Marsupial
Post by Wombat » Mon May 04, 2009 6:55 am
ABM make a top yoke conversion kit for the TRX. Here in Aus its about $350
jackfrost
Post by jackfrost » Wed May 06, 2009 10:10 am
Wombat wrote:ABM make a top yoke conversion kit for the TRX. Here in Aus its about $350
Cheers everyone for the help. Much appreciated. Bob, do you have a contact no. or address for ABM?
Slow Codger - what did you use as spacers under the bar clamps?
Thanks again. Youse are grouse.
esse quam videre
Post by slow codger » Wed May 06, 2009 10:46 am
:D Just used a bit of of aluminium turned and drilled , small engineering place will knock them out for you over lunch break.
Post by trixynut » Wed May 06, 2009 11:33 am
...or a pile of washers.
devlin
Post by devlin » Wed May 06, 2009 1:17 pm
I tried the pile of washers tonight but wasn't satisfied with the setup. I ended up with two cupped washers each side that were spares from some mtb brakes. I dropped the yokes about 12mm the other night but didn't like the handling. Felt like it was pushing wide once into teh turn. I dropped it another 10mm tonight so the forks had 40mm showing with the bars in teh normal position. I then raised the bars up about 10-12mm. I am hoping this will stop the tendonitis i am getting on the inside of my elbow when I ride. Went for a quick ride tonight when I finished and front end feel is much better. Turn in is awesome and I have the confidence to push the front which doesn't drift wide now.The bars in relation to the seat feel better too. Commute to work will reveal the extent of effect.
Post by Mincehead » Wed May 06, 2009 7:12 pm
Here you go Jackfrost,you`ll be able to get one here: :wink:
http://www.streetfighterstore.com/yamaha_top_yokes/91
jackfrost
Post by jackfrost » Fri May 08, 2009 8:20 am
Have I mentioned youse all bloody rock?!
TRX-850 must attract a top sort of human 8)
Will keep you posted.
esse quam videre
devlin
Post by devlin » Fri May 08, 2009 8:35 am
We're all just nice mellow guys and gals who like to torque.... um..... talk.
