Sump oil level problem?
Thom
Re: Sump oil level problem?
Post by Thom » Tue Jun 07, 2011 8:50 am
Ohhh... :/ maybe i should go find another 200ml of oil :oops:
We'll try that first.
Post by phuk72 » Tue Jun 07, 2011 9:52 am
Thom wrote:Ohhh... :/ maybe i should go find another 200ml of oil :oops:
But it still will not register on the sight glass until the engine is running / has been run hot.
Thom
Post by Thom » Tue Jun 07, 2011 3:47 pm
VICTORY!
So the problem wasn't oil level, as after adding an extra 500ml it still did not register, so i drained all the oil which was infact sitting in the sump.
After removing the sump i checked the pressure valve thing and it was fine, i stripped it and reassembled it to find no problems, also the bearing valve was fine.
I took a trip to mr.haynes and noticed something i didnt think could have been the problem!
The strainer was about 90-95% blocked with crap much of it metallic!
It was amazing the engine hadnt blown!
After cleaning the sump and the strainer of all the crap i reassembled, cracked an exhaust holder thingy, and snapped a stud, however with what little of the exhaust i had on i ran the bike and the oil is circulating beautifully.
At last.
Now i need two exhaust clamps and four studs.
Post by Mincehead » Tue Jun 07, 2011 4:46 pm
So if the oil strainer was almost blocked it was the scavenge pump that was struggling to pump oil back to the tank, you actually had a wet sumped TRX!
At least all the clean oil assured the motor was fine while you`ve been running it up trying to ascertain the problem, especially as you`ve not been running it at high speed or for long periods.
How the ferk did you break one of the alloy exhaust collars :shock: or do you have a non standard system fitted?
Post by handsomejackuk » Tue Jun 07, 2011 6:31 pm
What Strainer ?
Al..
Post by Mincehead » Tue Jun 07, 2011 6:56 pm
The course oil strainer in the sump Al. I take it you`ve never cleaned it out? Mind your`s only having covered 10,000 odd miles it probably doesn`t need it. :wink:
Post by handsomejackuk » Tue Jun 07, 2011 8:04 pm
hmm....
oil has been changed... prob about 4 or five times... usually do it every other year....
change the oil filter but never dropped the sump...Do you think this should be done.... do i need any sump gaskets or owt...??
Al...
Post by alextrx850 » Tue Jun 07, 2011 8:40 pm
a sump strainer???ok i guess that there might be a coarse item strainer in the works there somewhere..but i am guessing that if Mr Yamaha wanted me to service it regularly, an access appendage would be fitted...so...i am thinking that a strainer must be for worst case cenario down in the bowels...i mean isnt the OIL FILTER doing as its designed under NORMAL conditions??..and i would be alarmed that there is enough metal floating around the engine thats not being processed by the filter full stop.!...cant imagine that a decent service includes taking the SUMP off...the Japanese just dont do things like that and i would be concerned with a motor that has this problem...the way things are going with our bikes these days ..if youve got a good one that has been serviced and cared for...keep it..cherish the mechanism..THEY ARNT MAKING THESE ANYMORE..
andyaber
Post by andyaber » Tue Jun 07, 2011 9:08 pm
There's a coarse filter in the oil tank also. Found out about it when I killed my first engine, it was mostly blocked and insufficient oil was circulating, just after buying it. It' a carbs off or engine out job I believe.
Post by Mincehead » Tue Jun 07, 2011 9:17 pm
The strainer catches those heavier pieces of metallic pieces that the oil doesn`t carry to the filter. Obviously there shouldn`t be too many of these particles present in a `happy` motor but many engines go on for years without them causing problems after they become lodged in the strainers mesh.
I will be checking mine seeing as she`s got over 20,000 miles on the clock now and I`ve never checked it. It`s prudent to check it every few thousand miles or so. :wink:
Thom
Post by Thom » Tue Jun 07, 2011 11:02 pm
Mincehead, one of the collars was cracked when i purchased the bike, probably due to over tightening, i simply finished it off today unfortunately!
