Rough running and oil from carbs?
NWS870R
Re: Rough running and oil from carbs?
Post by NWS870R » Fri Jul 22, 2011 5:41 pm
The bikes been apart quite alot recently? It may be as simple as a little debris in the carbs (i've just had a similar problem with my FCR's) As a simple check try undoing the drain screw at the bottom of the bowls to drain them (obviously with the main fuel feed disconnected) connect a length of hose to the fuel feed into the carbs & give them a good blow thru which should shift any particles that may be sitting in any of the jets. If this doesn't sort it i'd say there's a good chance it's a float height issue.
Thom
Post by Thom » Fri Jul 22, 2011 11:34 pm
Its both float bowls mate and theyre as clean as - having just cleaned the set of carbs last week and the float bowls yesterday upon changing the emulsion tubes.
NWS870R
Post by NWS870R » Sat Jul 23, 2011 12:28 am
Just a thought - always worth trying the 'cheap & easy' route first
BigAl-TC
Post by BigAl-TC » Sun Jul 24, 2011 1:37 am
Are the fuel and breather lines on the right spigots ?
I'm trying to think simple :lol:
Alan.
