Engine noise on a positive throttle,
johnktm
Post by johnktm » Tue Jun 03, 2014 1:04 pm
Hi all, I joined a while ago but not really had a lot to say,just been enjoying the TRX,but now I have a question I hope someone can help with,the bike seems to have developed a dull rattle when accelerating,seems to be coming from the right hand side of the motor,is particularly noticeable above 4000revs but disappears on a neutral or closed throttle.
I am thinking clutch related? but any theories,past experience would be appreciated.
Thanks in advance.
johnktm
Re: Engine noise on a positive throttle,
Post by johnktm » Tue Jun 03, 2014 5:12 pm
Hmm, never mind, I think I may have a prime suspect,
Snod Blatter
Post by Snod Blatter » Tue Jun 03, 2014 7:36 pm
Crikey! Any idea how that happened? Never seen anything like it before.
johnktm
Post by johnktm » Tue Jun 03, 2014 7:45 pm
I'm hoping it's just down to old age/wear and tear, I am guessing they are the original plates and it is just coming up to 30000miles.
Post by Con Rod » Wed Jun 04, 2014 12:42 am
Been doing any wheelies?
johnktm
Post by johnktm » Wed Jun 04, 2014 1:01 am
No,but I suppose I am not the smoothest/gentlest on the throttle,I have come to the TRX after a succession of KTM v'twins,I like to use lots of engine braking into corners and try to give it as much grunt as I dare on the way out.So maybe I've been a little rough on the old girl given that things like the clutch are probably 17years old.
Post by cobbadiggabuddyblooo » Wed Jun 04, 2014 2:12 am
Ouch.. Someone has been dropping the clutch or race starts previous in its life maybe
johnktm
Post by johnktm » Mon Jun 09, 2014 12:25 am
Oh well,that wasn't the problem.
On the way home from work today the dull rattle escalated to a serious clattering and the motor locked up, me thinks it be fooked :(
Post by dixonj » Mon Jun 09, 2014 11:27 am
You have PM
