Brake pad info and coding
Post by cobbadiggabuddyblooo » Wed Dec 10, 2014 12:49 pm
Shopping for brake pads at the moment and cut this from a site while on my search,
Let's look at how a brakepad is made.
Resins are used to hold the brake pad materials together such as the friction materials being fibreglass, kevlar or arimid. Steel and aluminum maintain the heat stability. There is also filler material such as saw dust. Sometime graphite is added to adjust friction level depending on temperature range of use.
Molding process
Are the pads pressed in a mold one by one or mass pressed? High performance brake pads are pressed one at a time. This would be more durable as the full pressure was applied.
Are the brake pads slow cured or rapid cured?
Usually after pressing the materials in the mold the brake pads go in an oven to remove moisture that is present in the friction mixture. Needless to say, slow curing is always better. rapid curing of the pads can put stress on the friction material by the moisture escaping too fast creating small cracking.
The codes on Brake Pads steel backing plate
The codes refer to the friction formulation and show the consumer its ranking in the chase test.
What is the 'chase test'?
This is where those two letter designation come. The chase test is assigned to add a two letter code that we often see on brake pads. EE, FF, GG, HH. Those letters specify the coefficient of friction when a 1" square piece of friction material is subjected to varying conditions of load, temperature, pressure and rubbing speeds on a chase machine.
The first letter refers to the normal friction coefficient. The second letter refers to the hot friction coefficient based on the fade and recovery test. Brake fade is when you notice brake power is less efficient. Recovery is where your pads are cooling down again.
H has the highest coefficient of friction. (superior braking power)
The friction coefficient codes are as follows:
C = < d =" 0.15" e =" 0.25" f =" 0.35" g =" 0.45" h =" "> 0.55
Now you would think that HH is all you need. Wrong. H might be braking to much if you're only commuting.Racing pads might never reach to the right working temperature... It's pretty much up to you which brake pad is best for you.
I am happy with EBC Sintered Double-H pads. Great pads, if you follow the break in guidelines you will stop a lot sooner and safer. Combine this with stainless steel brake lines and braking will be excellent. Break in: 10 stops from 80 to 40mph. Use some 220 sandpaper on the rotors to remove old pad residue.
A handy link on cleaning the calipers too.
http://www.bikesandtravels.com/biker.aspx?ride=156
Stu99
Re: Brake pad info and coding
Post by Stu99 » Wed Dec 10, 2014 9:59 pm
Good info Cobba. :thumbup:
I have been using DP brake pads of late. Best I have used to date. But it's always a personal feel thing.
I have been using the SDP compound in my 'busa and they pull that heavy beast up real nice. A set will also be going into the TRX trackie as it gets ready.
Here is a link for anyone interested, http://www.dp-brakes.com ,as you probably don't want to google DP. :lol: :lol: :lol:
Post by cobbadiggabuddyblooo » Thu Dec 11, 2014 2:55 am
:lol: :lol: yer I have been drawn towards the DP myself .. Good feel was the feedback I found.
Stu99
Post by Stu99 » Thu Dec 11, 2014 9:55 am
Yep, soooooo much feel. :D
No shortage of bite either.
Trixed
Post by Trixed » Thu Dec 11, 2014 11:56 am
I had simitomo, good ridge, ferodo. Removed the new ferodos and replaced with ebc. The difference is chalk and cheese. Great feel and great bite. Am a convert now.
Post by misterdimwiddy » Fri Dec 12, 2014 1:29 pm
Brembo SC pads for me; pricey but no lag and very powerful.
They wear at a sensible rate too even on the track. Use 'em in my Tuono now :D
