Where is this pipe from?!??!
[JP]
Post by [JP] » Sun Mar 04, 2007 5:47 pm
Well... today while doing the oil change and tightning the headsock I found this little pipe...which seemed to be disconnected?
Couldn´t find anything in the manual, but by the way it was bent I figured out that it might be long to the other bit where I connect it?
the pipe that was loose was the one with the red arrow...and all seemed to point that it should be connected to the bit with the blue arrow, this bit looks like it´s part of the frame, is this some breather that will drain through the frame tubes and to the floor??
btw.. this is on the left hand side of the bike...
Thanks!!
Image PORTUGUESE MADNESS
Post by trixynut » Sun Mar 04, 2007 7:18 pm
JP,
Yep, pretty sure you got that right: connects to the pipe on the frame. It is some sort of drain/breather pipe, but dunno what though: petrol overflow drain from the carbs. Can't remember without going in the garage to look and it's pi55ing it down here!
Dave.
[JP]
Post by [JP] » Sun Mar 04, 2007 7:48 pm
yeah... it´s pissin there and here.... has been raining all day, so I picked the perfect day for maintenance on the bike! hehehe
yes, that´s what i thought, because the pipe come from the carbs...
Post by ekoja » Sun Mar 04, 2007 10:15 pm
Thats where that pipe connects to on my bike, :lol:
P.S. I wish it would start pissing down here, The country is running out of water. Its going to be about 31 degrees today in Queensland, bloody humid as well. :roll:
burty
Post by burty » Sun Mar 04, 2007 10:33 pm
I think it's a breather, probably Mr Yamaha thought it a good idea to breath it into the frame, helps with corrosion resistance I guess.
