Coolant problem
Jcb
Coolant problem
Post by Jcb » Tue Mar 07, 2017 6:38 pm
Hi.
New to the site and looking for a bit of advice.
Rebuild on my bike and just connected up the rad with new coolant but temp gauge running
Up to 80 and it's never done that before. I've checked that the fan works at least but not sure about anything else.??? Help!
Snod Blatter
Re: Coolant problem
Post by Snod Blatter » Tue Mar 07, 2017 7:03 pm
What else did you do in this rebuild?
Jcb
Re: Coolant problem
Post by Jcb » Tue Mar 07, 2017 9:10 pm
Oil and filter change. Removed ignition switch, changed plugs.
The rest was bodywork.
Re: Coolant problem
Post by Mincehead » Tue Mar 07, 2017 11:25 pm
You sure the coolant is circulating properly?
Jcb
Re: Coolant problem
Post by Jcb » Wed Mar 08, 2017 8:14 am
I'm not sure how to check that. I can see the level in the rad rise once the engine is turned off.
Re: Coolant problem
Post by Mincehead » Wed Mar 08, 2017 9:41 pm
Is the coolant visibly flowing when you look into the radiator with the engine running?
Jcb
Re: Coolant problem
Post by Jcb » Thu Mar 09, 2017 7:02 am
Just checked my fan thermostat and it is kaput. There does appear to be movement in the water.
Is there a go to replacement fan thermostat or is it main dealer?
PrfctChaos
Re: Coolant problem
Post by PrfctChaos » Fri Mar 10, 2017 1:50 am
If you are just after a fan switch, then i've used one of these previously. They go for $30. M16x1.5, you can choose your preferred switching temp, I used a 85-90 degree.
http://www.ebay.com.au/itm/75-80-Deg-C- ... SwSlBYvSQ-
Jcb
Re: Coolant problem
Post by Jcb » Sun Mar 12, 2017 7:54 am
drained and refilled the coolant yesterday, fitted a new thermoswitch and still no joy.
With the rad filler cap off, when i start the engine the coolant level drops and im sure that there is movement, otherwise where else is it going when it drops.
does anyone think an airlock is possible?
gonna go back and check that the new switch is working. might try a lower operating temperature switch.
Re: Coolant problem
Post by Mincehead » Sun Mar 12, 2017 1:50 pm
With the rad cap off and holding say 2000 revs you should see the coolant circulating. :wink:
Jcb
Re: Coolant problem
Post by Jcb » Tue Mar 14, 2017 7:00 pm
Tested the new switch suspended in a boiling pan of water and no circuit so I guess that's duff too.
Any UK options available.
Removed and checked thermostat works.
Where abouts on temperature gauge does anyone else's sit?
Snod Blatter
Re: Coolant problem
Post by Snod Blatter » Tue Mar 14, 2017 9:45 pm
Riding around it stays not far off the stop, but sat in traffic mine has been very lively ever since I replaced the emulsion tubes. A solid 5 minutes sat in traffic is a big problem.
Re: Coolant problem
Post by Mincehead » Wed Mar 15, 2017 8:21 am
You CAN fit a manual over ride switch guys. :wink:
Bostel
Re: Coolant problem
Post by Bostel » Thu Mar 16, 2017 1:02 am
Could it just be a loose connection in the wiring? Bad connections can lead to faulty readings.
I have an aftermarket oil temp gauge in my car, one day I had a problem that my oil temp was getting higher then normal. But then I realised that I worked on the dashboard the day before. After inspection i found that the ground wasn't wired properly to the gauge.
BigAl-TC
Re: Coolant problem
Post by BigAl-TC » Thu Mar 16, 2017 6:04 am
80 isn't to bad. Is that sitting in the shed or mobile ? Mine sits on 70 on the road, If I run it up in the shed it goes to 100 then the fan kicks in dropping it back to 70 or 75.
70 on the road is with ambient temp at 30 c approx.
Cheers :-)
Alan.
