Close to getting my YZF rear wheel in with 180 tyre.
The 180 tyre is about 63cm diameter, and the 160 rear is about 59cm. Is this gonna effect my gearing much?
Anyone out there that can do the maths?
Dave.
YZF rear and 180 tyre...
- burty
- burty
Dazzling
Re: YZF rear and 180 tyre...
im thinkin of putting R1 Rear Wheel On any info would be greatly apreciated . Dazz
You`ll have to modify the stock TRX swingarm if you really want to go down that route, R1 uses a bigger diameter wheel spindle and I seem to recall that you cannot get bearings with an o/d to suit the R1 wheel, but with an i/d to suit a TRX wheel spindle.
Unless somebody knows different
Go Thunderace swingarm with rear wheel assembly and you can have the larger diameter rear wheel spindle though.
