pine
by pine » Wed Apr 22, 2020 2:03 pm
Sorry all, got another super basic question!
I'm trying to clean back the tail of this frame from rust damage and on getting to it all I need to remove the plastic tail box.
It looks like the only thing holding it in are some pipes...
Any ideas if I'm good disconnecting these or is it gonna cause some problems later?
Thanks and sorry for being so vague! :/
pine
by pine » Wed Apr 22, 2020 2:18 pm
It looks like they all go to the regulator..
pine
by pine » Wed Apr 22, 2020 2:46 pm
...and come from the engine and fuel tank. Starting to wonder if I can take this plastic off without messing with the fuel system ( which I'd rather avoid where possible!)
pine
by pine » Wed Apr 22, 2020 3:18 pm
...shouldn't have been so quick to post. Got it off.. a bolt holding the fuel system to the plastic box separated it fine. Regulator unscrewed under battery.
HolerTogni
by HolerTogni » Wed Apr 22, 2020 3:53 pm
TRX 850 & Racetrack-TRiXie
by cobbadiggabuddyblooo » Fri Apr 24, 2020 8:34 am
Glad to hear all came together for you.
Easiest way is take a number of pictures and anything cable, hose etc label it so you have a reference and right down the way you removed it.
