Can't find neutral with the engine running
PhatVR6
Post by PhatVR6 » Mon Aug 06, 2007 7:43 pm
I just cannot find it unless i knock the engine off, then it's straight in.
Is this because it's idling at 1500rpm? I have to have it idling high as the carbs need a good setup and new emulsion tubes and it stalls otherwise.
Post by phuk72 » Tue Aug 07, 2007 7:56 am
Is it always like that?
Try going into to neutral from 1st rather than 2nd?
PhatVR6
Post by PhatVR6 » Tue Aug 07, 2007 9:57 pm
managed to wind the idel down to 1000. it's easier now
doesn't seem to want to go in smoothly at all when going up from 2nd.
I've had it pop out of gear a few times too, and there's a few fasle neutrals in there but not very often. Is that normal?
Post by phuk72 » Wed Aug 08, 2007 9:29 am
Sounds as if the selector is bent
philk
Post by philk » Thu Aug 09, 2007 10:44 pm
Clutch adjustment will also have this effect.....
:roll: :roll: :roll: :roll: :roll: :roll: :roll: :roll:
Reminds me of my ypvs days....
All hail the HYPNO-TOAD
http://r33b.net/
Post by phuk72 » Fri Aug 10, 2007 2:23 pm
philk wrote:Clutch adjustment will also have this effect.....
My first thought but that wouldn't cause the bike to jump out of gear
Post by youngy » Fri Aug 10, 2007 2:30 pm
I'd agree. Clutch might make selection difficult but shouldn't cause it to jump out of gear.
As you say Phuk........could be bent (or worn) selector, or maybe a worn selector drum.
