tyre pressures
dillthedog
tyre pressures
Post by dillthedog » Sun Aug 19, 2007 8:58 pm
could someone tell me the correct pressures please in psi
Post by Jak » Sun Aug 19, 2007 9:54 pm
Manual says:-
Load up to 90kg
Front = 2.25 bar 33 psi
Rear = 2.5 bar 37 psi
Load over to 90kg
Front = 2.5 bar 37 psi
Rear = 2.8 bar 41 psi
To convert from bar to psi ...... multiply the bar figure x 14.7
Post by youngy » Sun Aug 19, 2007 10:38 pm
It may also be worth checking what the manufacturer of your tyres suggests. Bridgestone, for example, suggest 36 front, 42 rear for their tyres on the TRX.
devlin
Post by devlin » Mon Aug 20, 2007 4:07 am
Local Yamaha dealer said 32 front 36 rear for Michelin Pilot Powers. Reminds me must check the serial number for that recall.
dfh
Post by dfh » Tue Aug 21, 2007 5:00 am
martin young wrote:It may also be worth checking what the manufacturer of your tyres suggests. Bridgestone, for example, suggest 36 front, 42 rear for their tyres on the TRX.
+1.. ask the mob that makes the tyre, not the bike manual- cos that will list the pressures for the OEM Crapadams and nobody uses them. And as for the wally at the dealer/tyreshop and his special pressure info... if he was that clued up he would'nt be working there...
DFH
Post by ekoja » Tue Aug 21, 2007 10:13 pm
Yet, I run my Bridgestones at 32 front 35 rear, No one recommended those pressures, but it just feels right. anything under that and I can feel the difference, not tried it above. Front setup is 26mm thru the yokes, 6 rings on the compression, all other settings are middled (I can't think of any other word to describe it) :roll:
P.S. I weight 90 kilos :oops:
twolfe
Post by twolfe » Tue Aug 21, 2007 11:11 pm
I run Bridgestones also, 32 front 38 rear. Like Ash says, it feels right for me. Terry Hay, the suspension guru, recommended similar figures. I also weigh in at the 90 kg mark.I tried them at 36 front and 42 rear but it felt like a billy cart ride.
Post by slow codger » Wed Aug 22, 2007 3:48 am
:D Bridgestone bt020 35 front 40 rear
H1
Post by H1 » Wed Aug 22, 2007 3:19 pm
Jak wrote:Manual says:-
Load up to 90kg
Load over to 90kg
Hi!
That´s what i can sign too (normal use, no racetrack!).
at
Michelin Pilot Sport
Maxxis Supermax
Bridgestone BT 010
Racetrack i go (over 90 KG)
front 2,1
rear 2,3
Ciao!
Heinz
Ciao!
Heinz
