Hi there, I would like to know your ideas about the following problem.
My TRX tends to shut off the engine after a little cruising, this happens during downshifting. So I just drive happily down the street untill I have to slow down. Close the throttle and grab the clutch (to change gears). The revs get beneath 500 rpm and the engine stalls. But! This does not always happen. And when you blip the throttle during downshifting it keeps running and standing still at some traffic lights or something, the engine just runs ~1000 rpm idle (so >500).
So any ideas what could be the problem here?
The bike has less then 25.000 km of experience.
Ideas about idling problems?
- Tarwetijger
- slow codger
- steve speed
- Tarwetijger
More info is hard because I have the bike very short and only drove 130 km. yet.
Important info is also: the bike runs fine! It runs good trough gears/revs and fuel consumption is very good (well, following the comments of the previous owner that is). So it's not just carb's that are worn out (otherwise I'll have noticed black smoke and high fuel consumption).
Yes, it does.slow codger wrote:Need a bit more info, does your bike idle properly when at a standstill,
The last option, it doesn't matter. Just when you release the throttle and pull the clutch, the revs drops too low.and when it stalls during downshift, are you letting the revs drop down to idle speed before pulling the clutch in, or does it stall no matter what the revs are.
- Tarwetijger
Wouldn't idling at stand still then be troublesome?martin young wrote:inlet air leak?
split intake rubbers?
damaged pilot screw?
Could be, but fuel consumption isn't too high...loose jets?
Could be, but the bike isn't very old (yr 2000, < 25.000 km)worn carbs?
Could be! I definitely have to check that.out of balance?
etc
