Engine Cover, how to seal it properly ?
jake
Ok the top cover where the cams are, is leaking on me, im getting a new rubber gasket that goes across, but what are your suggestions for doing it properly ? should i use some sort of silicon ?
Cheers guys
Cheers guys
99 TRX850
02 GSX-R600
02 Hyosung Comet 250
02 GSX-R600
- honkdawillydahonk
I read somewhere that one should change gasket after the valvecover has been off for three times....correct or not i don´t know but mine is also leaking and i have bought myself a new one for change this spring.jake wrote:yeah i had one that i thought was in good condition, and now its leaking, hence why i have to it again. I think i might put on a bit of silicon.
- steve speed
- Quan-Time
long as everything is cleaned well, a new gasket should be fine.
I personally wouldnt use any sealing silicone. If that stuff gets into your oil filter... yer.. its not pretty.
If you DO use silicone, make sure you use it very sparingly. dont blob it on.
