only getting 195 kms avg from a tank's worth????
Loud Pipes save Lives
Post by Loud Pipes save Lives » Fri Mar 28, 2008 7:35 am
Hello all,
Dazza here, just wondering what i can do to trouble shoot my fuel issue. ive been told i should be getting around 250-270 kms from a tank. is this right??
im getting only around 190 kms, ggggggggggggggggrrrrrrrr
things that come to mind to fix or replace are ,
- tuning carb (balanced)
- replace emulsion tubes (what should i look for as signs of damage for reason to replacing them)
- replacing all rubber tubes that comes out of the fuel tank.
have i missed anything.?
ps my idle rev range avg. 1200rpm
[-o<
Re: only getting 195 kms avg from a tank's worth????
Post by phuk72 » Fri Mar 28, 2008 8:54 am
search for emulsion tubes or fuel economy and your answers will magically appear
Post by youngy » Fri Mar 28, 2008 11:01 am
^^^^^^ ditto
Really no point in replacing them rubber hoses as it won't have any benefit (unless you can see fuel leaking out).
Post by phuk72 » Fri Mar 28, 2008 12:04 pm
It also depends a lot on how you ride
195 kms is approx 120 miles
Presume by tankful you mean to reserve which is approx 15 litres
15 litres is 3.3 galloms
120 / 3.3 = 36 mpg
if you ride hard that would be about right
PAULT
Post by PAULT » Tue Apr 01, 2008 10:51 am
Hi,
Not much help but I get 250k's min and often just over 300k's before reserve. Raceco emulsion tubes, Mig race cans, 42, I think, rear sprocket, 87,000k's.
I live in the French Alps so there is a lot of 1st, 2nd gear work and loads of up and downs. I only weigh 58kg's so maybe that helps!!!
Paul.
