front fork upgrade r6 ???
BOB.T
Post by BOB.T » Sat Apr 26, 2008 6:21 pm
HI all ive got the opportunity of getting a set of r6 forks with wheel attatched am i right in thinking that they will
slide straight into the lower / upper head stocks without any major work ` i have the blue pot callipers on the standard forks and hope that the r6 forks will help with the handling. :dontknow:
ride loud - ride fast - ride safe
http://www.bikepics.com/members/tuareg/96trx850
Re: front fork upgrade r6 ???
Post by youngy » Sat Apr 26, 2008 6:26 pm
not sure what you mean by upper/lower headstocks??????
If you mean yokes, then the answer is no.
TRX forks are 41mm, R6 are 43mm.
BOB.T
Post by BOB.T » Sat Apr 26, 2008 10:32 pm
thanks youngy for your prompt reply yes i meant yokes . #-o
Post by Quan-Time » Sat May 10, 2008 9:16 am
also the fact they are a touch wider on centres aswell.
You CAN press out the stork / steering stem on the bottom yoke on the R6 / TRX, and swap them over, press them back in. You will need to make an adaptor washer so the lock nut tightens up properly.
Search the forums, this has been covered more times than ive had hot dinners.
