I have an N-reg Yamaha TRX with a rather bizarre carb problem. Basically I stored it over the winter, had it running in the garage once to charge up the battery, and then on the first ride a few months ago, noticed that at 3/4 throttle, if you opened the throttle to full, the bike died completely. However, rolling back the throttle gently allowed the bike to run ok again.
It was fine before the winter, so what could have changed? It sounds like a main jet issue but it was running fine before I put it away.
Anyone got any ideas or had a similar problem?
Jasper
TRX Carb problem
- steve speed
Re: TRX Carb problem
could be the old fuel , it turns to jelly if left for to long , it may just clear itself if your lucky then again you may have to strip your carbs down and give them a good clean , while your in there have a look at the needle jets there probably oval
- idl1975
Or you're running out of fuel (float bowl level, fuel feed from the tank, fuel tap, fuel pump)? Did you check all the hoses between tap, pump, tank to make sure everything's intact and still connected? Just something else to consider, and it's quick to check.
jasperloco wrote:I have an N-reg Yamaha TRX with a rather bizarre carb problem. Basically I stored it over the winter, had it running in the garage once to charge up the battery, and then on the first ride a few months ago, noticed that at 3/4 throttle, if you opened the throttle to full, the bike died completely. However, rolling back the throttle gently allowed the bike to run ok again.
Jasper
'04 Aprilia Tuono Fighter
'00 Scooby Sport Wagon
'76 TY250.
'76 TY250.
I had a similar problem: wooly running / no pulling power up the rev range. Took it to the Yam shop and the balanced the carbs and it was sorted.
- Omegaman
i had similar problems then it wouldnt start shortly after that
i changed the jets and emulsion tubes and also ditched the fuel as it been sat for 3 months ( cleaned out the tap and gauze etc whilst it was empty )
that sorted mine
that sorted mine
Its all fun and games till someone gets poked in the eye.
gregs656
old fuel in the jets blocked them up? That's what it sounds like to me.
The Hunt Continues . . .
