exhaust downpipes seized on!!!
neilb10000
Post by neilb10000 » Wed Jul 30, 2008 12:22 pm
Hey folks,how are you all?it`s probably been covered before but i can`t seem to find it.
I`ve just aquired an akra system but the original is seized solid....whats the best way of getting the downpipes off without damaging the bolts that stick out of the motor?Thanks :D
Re: exhaust downpipes seized on!!!
Post by phuk72 » Wed Jul 30, 2008 1:48 pm
take your pick! wd40, heat, hammer, jemmy, anngle grinder or none of the above.
Post by trixynut » Wed Jul 30, 2008 2:05 pm
Yep, been covered a lot: search harder! :D
No miracle cure, and any of Phuks suggestions are as good as each other. Bolts and collar can react somehow and almost weld together. Mine were a bitch!
My method ended up being soaking in penetrating oil or WD40, then hit with a hammer (and cold chizel is you're brave enuff!) to loosen, then undo the retaining bolt on the headers under the engine and try to use the headers as a lever to put pressure behind the collars to wiggle/pull them off. Heat helps too, to get the oil to go in and to 'soften' things up a bit.
Good luck buddy!! :shock:
brockzila
Post by brockzila » Thu Jul 31, 2008 2:59 pm
its not easy
mine were so corroded i had to cut the bolts. salt gets in betweeen the bolt and the flange and rusts the bolts and locks them solid. my engine guy tried every night with a big f&$k off presss and wd40 forr a week, but could not get the left over stud out.
i ended up cutting a slot in the side of the flange and using a wire wheel on a drill to remove as much of the rust as possable then a hammer and a punch to lossen them and remove.
you may just have to use a grinder to cut the old flanges off or risk damaging the studs.
Is it Brock friendly???
burty
Post by burty » Thu Jul 31, 2008 7:27 pm
Angle grinder worked for me
But made lots of aluminium dust in the Garage.
I also still managed to break a stud, which I eventually managed to drill out.
neilb10000
Post by neilb10000 » Thu Jul 31, 2008 9:19 pm
:D and they`re off!!!!!!!!!!!!!
attacked the little bastids with a Dremel flexible attachment thingie and cut them off.
Now just got to nicely ask the engineers at work to make me a bracket for the Akra as only one of the brackets i got with it fit.The other one is too small.
Trixz
Post by Trixz » Fri Aug 01, 2008 3:54 pm
neilb10000 wrote::D and they`re off!!!!!!!!!!!!!
It did cost me some hours of drenching it in some penetrating oil, then one hour for both sides and with some perseverance of a wrench tool the job was done.
Not that my information will help now, you've got them loose already! A job well done :D
neilb10000
Post by neilb10000 » Fri Aug 01, 2008 9:15 pm
Thanks!!i did spend about 4 hours the other night with wd40,a hammer,screwdrivers etc....
Then thought....sod it!!!!cut a big v slot at each end of the brackets....brackets off,bolts intact.....you Beauty. :D
Red Rex
Post by Red Rex » Sat Aug 02, 2008 10:26 am
... which I suppose leads on to the next question.
If you've finally managed to remove the standard flanges witout resorting to butchery, and the studs are still untact, what mods or precautions should you take when re-assembling the exhaust pipes into the head to avoid problems in the future?
In my experience "Copper" grease or similar sets like glue, hi-temp grease melts and runs out anyway, so should we
a) open out the holes a tad 8-[
b) apply a squirt of WD40 on a weekly basis :shock:
c) remove the pipes more often [-(
d) forget it and winge & moan in a couple of years when we have to go through it all again. #-o
Post by slow codger » Sat Aug 02, 2008 11:29 am
:? Use different ends, could use bolts, put threaded studs in and decent nuts, silicon spray?
brockzila
Post by brockzila » Sat Aug 02, 2008 11:57 am
if you saw mine you would undertand how screwed up these things can get. even after cutting a slot bigger than yhe stud i still had to use a chisel to chip the build up away and then smack the bit out with a hammer and a punch.
if i did not already have the slots i would oversize the hole and maybe fit stainless studs to stop the rust,
i also agree with putting it in to our services to just simply remove the flanges and descale the studs and clean out the holes. it will take only like 10 min and like all those that have had the problem know its a bastd and can take many many hours of frustration and pain and then you still just end up cutting them up.
neilb10000
Post by neilb10000 » Sat Aug 02, 2008 2:14 pm
Red Rex.....i`ve done step a....but think step d is more likely.... :lol:
haggisbash
Post by haggisbash » Tue Aug 05, 2008 9:14 am
Has anyone ever tried loosening the nuts and then running the engine till its hot. Alternate this with the WD40 soak.
Trixz
Post by Trixz » Wed Aug 06, 2008 10:10 am
Red Rex wrote:... which I suppose leads on to the next question.
I would go for option a, but now with my new exhaust the downpipes are grinded a bit down for better clearance and for an easy switch back to original :)
neilb10000
Post by neilb10000 » Wed Aug 06, 2008 10:22 am
haggisbash ...i tried running the engine with nuts off and i didnt work.i tried everything i could think of and the last resort was to cut them off.
