Front wheel bearings
haggisbash
Post by haggisbash » Sun Oct 05, 2008 4:11 am
Before I dismantle my front wheel (failed WOF on wheel bearings) does anyone know the bearing No? Are they available from bearing specialists or do you have to get them from Yamaha :?:
honkdawillydahonk
Re: Front wheel bearings
Post by honkdawillydahonk » Sun Oct 05, 2008 7:40 am
B and C Express are good for bearings... Just make a note of the number when you take them out and order on line (Metal shielded ones are best for wheels) alternatively try here:
http://simplybearings.co.uk/shop/index. ... QgodyVRAEg
<Edit> Just realised you didn't want to take your wheel out first....
billyboy25
Post by billyboy25 » Sun Oct 05, 2008 10:40 am
6204 RS?
steve speed
Post by steve speed » Sun Oct 05, 2008 2:37 pm
6204rs means rubber seal do what honk says ,,and koyo is a good make , just make sure you DONT bash them in with the centre , and make sure you fit the spacer :D
billyboy25
Post by billyboy25 » Sun Oct 05, 2008 2:48 pm
steve speed wrote:6204rs means rubber seal do what honk says ,,and koyo is a good make , just make sure you DONT bash them in with the centre , and make sure you fit the spacer :D
I know rs means rubber seal! I was trying to remember the bearing number,hence the ? Use the old bearing to knock the new one in :wink:
steve speed
Post by steve speed » Sun Oct 05, 2008 2:52 pm
ok ok ,, i will keep my gob shut [-( [-( [-(
billyboy25
Post by billyboy25 » Sun Oct 05, 2008 3:24 pm
steve speed wrote:ok ok ,, i will keep my gob shut [-( [-( [-(
Didn't mean it like!!!!!!!! :oops:
haggisbash
Post by haggisbash » Sun Oct 05, 2008 9:08 pm
Thanks, will go see the local suppliers today :D
Post by cobbadiggabuddyblooo » Mon Oct 06, 2008 5:58 am
cost me $6.00 for a set of front bearings from yamaha.. not that expensive. Same price as a stubby of coopers over the bar :shock:
haggisbash
Post by haggisbash » Mon Oct 06, 2008 6:06 am
Must've odd wheels on my japanese market model, turns out the bearings are NTN 6203LLU/2AS :? Anyway, I've got some plus the seals :D
honkdawillydahonk
Post by honkdawillydahonk » Mon Oct 06, 2008 6:43 pm
haggisbash wrote:Must've odd wheels on my japanese market model, turns out the bearings are NTN 6203LLU/2AS :? Anyway, I've got some plus the seals :D
6203 then....
Post by Greg » Mon Oct 06, 2008 8:15 pm
It's already been said about not whacking the centre race when fitting, but still take care when drifting the outer into the hub, unless my hub's been overcut (unlikely) I found resistance turning my wheel after fitting new bearings... I'd walloped the outers fully into the hub so that they gripped the spacer tight - just tapped them out a fraction again and free turning was restored.
G
:motard:
steve speed
Post by steve speed » Mon Oct 06, 2008 8:24 pm
Greg wrote:It's already been said about not whacking the centre race when fitting, but still take care when drifting the outer into the hub, unless my hub's been overcut (unlikely) I found resistance turning my wheel after fitting new bearings... I'd walloped the outers fully into the hub so that they gripped the spacer tight - just tapped them out a fraction again and free turning was restored.
G
i know what your saying but if the spacer is not touching the inner race then when you tighten the front wheel nut up would this not pre load the bearings against the side of the track ?? it may not cause a problem , but ,,,just a thought !! :? :?
Post by Greg » Tue Oct 07, 2008 2:29 pm
Yeah - I hear you, but I remember the spacer being slightly loose when I removed the bearings - if you think about it it needs to be so you can get the edge of your drift onto the bearing to remove it..!
I'd banged mine in tight, the spacer was gripped and I can only assume that by doing so I'd used whatever lateral tolerance there was in the bearing, and tightening the axle simply nipped the bearings even more ... I think it can only be a couple of tenths of a mm, not enough to make a difference to the seating of the bearing IMHO ...
I'll not tell you what I did when I refitted my output shaft seal... :oops:
I haven't done it since...
G
:motard:
Steve
Post by Steve » Fri Oct 31, 2008 1:21 pm
Done mine a few months back and they were sods to get out as they were tight up against the centre spacer tube :evil:
That and the fact i got robbed for the bearings from a local bearing supplier - ok they were PKF but nearly a tenner each ffs!
and did the rears too.
Still shouldnt need new un's for a while.
Red 97' Rex + Black/bronze '53 Falco
