Uncomfortably numb
zod
Uncomfortably numb
Post by zod » Thu Jan 22, 2009 8:43 pm
When I'm riding longer distances, my fingers are getting seriously numb.
It's both uncomfortable and makes me loose brake and trottle feeling.
As my right hand gets numb first, I guess its a bit of "over gripping" from my side.
I tried loosening my grip, putting in some heavier bar ends and a "trottlerocker" but it did not make much difference.
A set of good old foam grips fixed the numbness, but made the grip kind of ehhh...spongy..
As I don't see many others complaining about this at the forum I'm vondering if my handlebars are vibrating more than usual.
Any thoughts?
Corners R Us
Re: Uncomfortably numb
Post by Corners R Us » Thu Jan 22, 2009 8:49 pm
Are your hands plagued by this condition in warm weather and cold or is it just cold? I find the only way to maintain 'comfortable' hands in the cold is heated grips. Never again will I ride in cooler temps without them. Only slight downside is that the grips have less give in them due to the need to protect the embedded heating elements. Here endeth my 2p's worth!
Corners
G Beale
Post by G Beale » Thu Jan 22, 2009 9:06 pm
If it happens in all weathers then you might need to take some weight off your hands/wrists a bit with slightly higher bars or try swapping them around left for right, right for left ?
Post by Jak » Thu Jan 22, 2009 10:29 pm
I know just how you feel zod, happens to me too. The fingers go completely numb in the cold or on the bike - mostly down to bad circulation though, it's not the bike's fault. I haven't tried heated grips, although I guess they'd help.
Post by cobbadiggabuddyblooo » Fri Jan 23, 2009 12:05 am
Easy...move to sunny Queensland down under..
Post by ekoja » Fri Jan 23, 2009 12:33 am
Yeah I get that as well, :( in fact I think most riders do.
Serious numbness could be caused by Carpal Tunnel, (Google it), although I find that glove fit has a lot to do with it, :shock: as I reckon if the gloves are a little too snug they cut off the circulation (to your fingers). #-o A throttle lock devise helps ease it, =D> as does a wrist rest thingy.
I sometimes ride without gloves and find that there is no numbness at all.
Kevtrx849
Moderator
Post by Kevtrx849 » Fri Jan 23, 2009 5:05 am
Spot on Ash, carpal tunnel it is. If it wasn't for the vista cruise control, riding would be a misery.
The only advice i can give is try bending your elbows slightly, you'll be surprised how much weight it takes off of your wrists.
( HENRY FORD )
Kayla
Post by Kayla » Fri Jan 23, 2009 7:01 am
I get numb fingers in cold weather but I think that's more down to my crappy gloves than the bike. The bike was quite uncomfortable when I first got it and I had a lot of pain in my wrists when out and about but when I raised the rear and dropped the front (effectively putting more weight on my wrists but changing the way I sit on the bike) the bike became more comfortable. Lever position is also very important. Set them right for you. You shouldn't have to bend your wrist upwards at all to reach the brake or clutch. One size doesn't fit all.
HolerTogni
Post by HolerTogni » Fri Jan 23, 2009 8:14 am
Hi zod!
Like
Kevtrx849 wrote: ...
methinks that it also has to do with the load on your wrists (and thus the blood circulation); I found that it helps not to bend the wrists (i.e. keep it as straight as possible) and unburden them as much as possible by not leaning on your hands but supporting your upper part of the body by means of the muscles of your back instead of leaning on your hands.
Cured greetings from Munich!
TRX 850 & Racetrack-TRiXie
steve speed
Post by steve speed » Fri Jan 23, 2009 5:08 pm
the stompgrip have helped me as its easy to hold on with the legs ,, so some of the weight is off my wrists :lol: :lol:
Post by slow codger » Sat Jan 24, 2009 7:23 pm
:D Raise the bars to the top of the forks, and put spacers under the allen screws, helped me and I also have rear sets, also drop your levers so that they are angled down about 30 degrees from horizontal so that wrists are not bending so much.
zod
Post by zod » Sat Jan 24, 2009 10:37 pm
Thx for your input.
At least there's some consolation in not being the only one with numb fingers :D
I'll go for the "right-left handlebar swap"-mod and raise the bars as high I can without getting in conflict with the fairing.
A set of progrips with a few more mm of rubber will be on my list to.
Red Rex
Post by Red Rex » Sun Jan 25, 2009 1:24 pm
... and for what it's worth, I fitted Capirex (?) grips (available from M&P etc) and think they're brilliant.
Standard grips were too hard. Foam grips were too big and squashy, Capirex are just right.
Love xxx
Goldilocks
