I did not have o-ring in front shaft
balancer shaft o-rings ?
- Rane850
why front balancer shaft does not have o-ring but rear one has. This info is in parts cataloque but work shop manual says both shafts have o-rings.
TRX850 bubum bubum - 96 and 98
XT500 -80 bum bum bum
Re: balancer shaft o-rings ?
I might be wrong but a measured guess would be that the rear balancer shaft has some interaction with an oil gallery,therefore the shaft is fitted with O rings to stop any `bleed` of oil,thereby causing an oil pressure loss.
Yamaha would not have bothered machining a groove in the rear balancer shaft for O rings if they were not required.
