I've got Oxford heated grips fitted and I don't think they'll come off without damage thanks to the SupaGlue used to fit them so this limits my choices a bit to ones that can be fitted over the existing grip.
The previous style (forgot the brand) was designed to fit between the switch block and the rubber grip and clamped to the switch block.
Not enough room between the grip and the block so I returned the unit and exchanged it for the one I've got on now.
As you can see, there's not a lot of room. My hand only just fits - with a glove on it's a bit on the tight side.
I know, I know, function over form, but it really looks hideous!
I've reversed the actuator lever so that it's up when locked - a bit harder to engage but easier to thumb it back down quickly to release.
Still a bit of drag on the throttle, exacerbated by the hot grip cable somewhat. I added a drop of oil and this improved matters without compromising the friction lock.
I can't help thinking there's a better way to do this, some sort of clamp that bears on the throttle cable disc perhaps. I'll see if the manual shows an exploded pic of this part so I can explain what I mean. Back later.
