Poor economy
- Kenny
Poor economy
Hi Guys Im getting really bad fuel economy on my bike. I get 140km to reserve thats riding at 60mph average. I have done so far oil, air filter, factory pro tubes, set fuel screws to 2 turns, floats set to 15mm. It has a K&N and twin scorpion cans on std downpipes. I have done a search but cant find anything else to do. Anyone help here please.
- slow codger
Re: Poor economy
Re: Poor economy
do you mean 140km (which is shite) or 140miles which is fine?
I get less than 80 miles to reserve on track and around 115 to reserve on the road (but that is hard riding). But on a motorway / autoroute I can get around 140 to reserve cruising at 90 (ish)
- Baasm
Re: Poor economy
I dont get it. My trx is doing 250 km (156 miles) to reserve. 300 km (190 miles) on a complete tank, this is at normal speed. I've also a factory pro kit and open airfilters. It must be your emulsion tubes. The needles of the factory pro kit is made off titanium.... this is much stronger/harder than stock. I think u have to check your air/fuel condition on the dyno.Kenny wrote:Hi Guys Im getting really bad fuel economy on my bike. I get 140km to reserve thats riding at 60mph average. I have done so far oil, air filter, factory pro tubes, set fuel screws to 2 turns, floats set to 15mm. It has a K&N and twin scorpion cans on std downpipes. I have done a search but cant find anything else to do. Anyone help here please.
Re: Poor economy
If it´s 140Km it must LEAK fuel!
(You mean miles huh?)
Got the full kit as Phuk and get out 230Km normal sunday riding...
Re: Poor economy
Official figures, standard engine:
Fuel capacity: 4 gallons / 18 litres
Average fuel consumption: 43 mpg / 70 kmpg
Tank range: 165 miles / 265 km
140km to reserve is about 22mpg. You sure?
If so, I'd strongly advise not to light up a ciggy within a 20 yard radius of your bike
- Kenny
Re: Poor economy
I got 142km (kilometers) this tankful to reserve there is no fuel leak it doesnt smell of fuel at all. I have fitted new factory pro needle-jets about 2 months ago.
- zod
Re: Poor economy
I have the factory pro needle-jets to.
I'm hitting the reserve after 260-270 km (kilometers) and that's even without thinking about the polar bears!
Re: Poor economy
Ferk a rook!
Even with FCR`s and my riding the induction whistles for fun I get much more than that.
Could one (or both) of the carbs float valves be sticking and allowing fuel to overflow I wonder?
Might not see it at tickover and while riding it`ll get swept along in your wake as the overflow tubes extend down past the clutch housing And cast subframe,exiting very low down under the motor.
More investigation is definately required.
- Kojak
Re: Poor economy
Never got mine below 48 mpg, turns in around 65 mpg on a lazy runout.
Re: Poor economy
Riding around town, that is to work and back, about 200ks to reserve.
If I go for a highway run then about 270 to reserve, these vary a little but have been like it for ever, like since I have had the bike.
Mind you I do not ride overly quick on the highway.100/120, cannot afford the fines.
Smithers
Re: Poor economy
Gads!! thats a hell of a lot of fuel......like it's being bucketed in to the intakes......would a perferated diaphram in your fuel pump deliver a substantial dose of fuel to an inlet tract via the vacuum hose that actuates the pump?
- JW-TRX
Re: Poor economy
I get about 14km/l. That is about 240km on a tank. How is your performance?
My friend on his TDM850 gets about 17km/l.
- Kenny
Re: Poor economy
Performance seems ok but the end cans are sooty so I know its rich even though the carb settings are std.
- zod
Re: Poor economy
With almost twice the fuel going in, you should have around 170 hpJW-TRX wrote:How is your performance?
