Side, rear and instrument lights dont work !
OFD
Post by OFD » Fri Mar 12, 2010 1:23 am
Hi. I have just completed my winter service,which included a valve clearance check, and on putting the wiring plugs back toghether the side lights dont work. I have a headlight and the indicators all work ok and the horn works but no side lights. I thought i had missed an Earth connection but i have had a good look but cant find anything.
Has anyone got any idea`s as it is beggining to warm up in the UK and LeMans is only 5 weeks away.
Gary
Motorcycling : The best fun you can have with your clothes on....
1996 TRX. Red. Leo Vince carbon cans,FCR 41 flatsides, YZF SP front, R6 shock with Projection adapter. Polished Wheel rims, Ignitech ignition. 93rwhp.. Oh yes !!
M.V.
Re: Side, rear and instrument lights dont work !
Post by M.V. » Fri Mar 12, 2010 8:07 am
Yes, those plugs are getting pretty old by now, probably lots of corrosion!
Take them apart & reinsert them a few times, or better yet some electrical contact cleaner if you have some.
Post by slow codger » Fri Mar 12, 2010 9:59 am
:shock: You have checked the bulb!
Post by phuk72 » Fri Mar 12, 2010 2:41 pm
checks bulbs, fuses, earths and connectors
OFD
Post by OFD » Fri Mar 12, 2010 4:41 pm
Thanks Guys
I am working all weekend so it will be monday before i have any garage time to sort this out. I will keep you posted.
Gary
OFD
Post by OFD » Thu Apr 01, 2010 12:18 pm
Fixed it.
Turns out to be the switch. A £20 purchase from Ebay and the problem is sorted.
Thanks for your ideas
Gary
