Part throttle fueling
Kenny
Post by Kenny » Fri Aug 06, 2010 12:05 pm
Hi I have a part throttle mid/high rpm lean stumble. On non CV carbs I know what circuit to look at but not CV carbs. What part should I adjust on these carbs float? Needle? I have no idea as the slide could be half way up on near a closed throttle with CV carbs.
Re: Part throttle fueling
Post by phuk72 » Fri Aug 06, 2010 12:23 pm
setting up carbs is something of a black art but ....
does the bike have any stumbling on WOT? And only at mid / high revs - 5k plus?
if the answers are no and yes, try lfting the needle a notch and report back
Kenny
Post by Kenny » Fri Aug 06, 2010 12:56 pm
The stumble is only at low throttle but 4000rpm + WOT is perfect. My floats are set at 15mm. needles are set at the highest already :?
Post by phuk72 » Fri Aug 06, 2010 1:07 pm
Kenny wrote:The stumble is only at low throttle but 4000rpm + WOT is perfect. My floats are set at 15mm. needles are set at the highest already :?
Have you had the needles at different heights? Option 2 is to drop the needle - it may be fluffy due to over fuelling in which case dropping will help.
of course, all of this is pure guess work. Can you confirm what size jets you've got, standard air filter, exhausts etc?
Kenny
Post by Kenny » Fri Aug 06, 2010 1:16 pm
K&N in airbox, Scorpion cans on std headers, 140 mains, mixture screw 3 turns, needle bottom clip.
Its a deffinate lean spot as when it happens and I open the throttle more it gets worse then picks up.
Post by phuk72 » Fri Aug 06, 2010 2:20 pm
Kenny wrote:K&N in airbox, Scorpion cans on std headers, 140 mains, mixture screw 3 turns, needle bottom clip.
the symptons you describe are often attributed to lean running but very often it is the opposite - i.e. it's running rich.
However, I suspect you are right. IIRC 142 is standard for main and you have freed up the breathing through the addition of cans and a K&N.
Either way, your plugs should give you an indication. If they don't, try up jetting a bit (or get it on the dyno for a definitive answer)
M.V.
Post by M.V. » Mon Aug 09, 2010 2:40 am
I suspect you've probably seen this;
http://www.factorypro.com/tech_tuning_p ... gines.html
Works for me.
