R1 UPSD Forks
SDN
R1 UPSD Forks
Post by SDN » Mon Sep 27, 2010 6:49 pm
Hello clever people, am looking to fit some R1 USD Forks, I would like to retain TRX wheel at least until I wear out the brand neww tyre. Also coz I am a cheapskate and like original instrument pod want to keep original speedo, can i modify speedo drive etc to work with R1 forks. If I have to I will figure it out, but if someone has allready done it, will learn from their success / mistakes
Re: R1 UPSD Forks
Post by Killerwhale » Mon Sep 27, 2010 8:16 pm
SDN wrote:Hello clever people, am looking to fit some R1 USD Forks, I would like to retain TRX wheel at least until I wear out the brand neww tyre. Also coz I am a cheapskate and like original instrument pod want to keep original speedo, can i modify speedo drive etc to work with R1 forks. If I have to I will figure it out, but if someone has allready done it, will learn from their success / mistakes
Mine was already done with distances and alu thingies in the fork bottoms so i run TRX wheel with the tacho shell.
I have Matris cartridge inserts to mount and then i have to take all out and can do measurements...but it´s a winter thing.
SDN
Re: R1 UPSD Forks
Post by SDN » Tue Sep 28, 2010 8:35 am
Thanks for the reply if you could post a photo, I can probably sort out the rest, have access to a lathe at the moment
Regards
Simon
