yzf shock
jjmoto
yzf shock
Post by jjmoto » Wed Mar 23, 2011 12:48 am
is a yzf750 shock the same length & a direct replacement for a trx?
Re: yzf shock
Post by cobbadiggabuddyblooo » Wed Mar 23, 2011 1:23 pm
I remember Kev saying something about the 750sp shock being produced by Ohlins and fitting straight in. Got an idea Red Barons got his old one from his trackbike. Expensive option and rare tho compared to a R6 option.
Kevtrx849
Moderator
Re: yzf shock
Post by Kevtrx849 » Wed Mar 23, 2011 9:19 pm
SP is an Ohlins ,not sure about the base model though. Yes it will fit but 3mm of material needs to be removed from the top leading surface for clearance.
( HENRY FORD )
jjmoto
Re: yzf shock
Post by jjmoto » Thu Mar 24, 2011 2:12 pm
Thanks for the info, spotted a Hagon for a YZF on ebay just pondering whether to go for it
Re: yzf shock
Post by cobbadiggabuddyblooo » Fri Mar 25, 2011 9:44 am
speaking to local suspension guy the other mth who was telling me that the internals on the R6 shocks have the same piston size and internals much the same as the ohlins so great value for an easy mod (thanks to kayla :wink: ) Seems to be plenty of positive feedback so far on these shockies for the money
jjmoto
Re: yzf shock
Post by jjmoto » Fri Mar 25, 2011 2:15 pm
only had the bike for few months so going to give the stocker a good clean & adjustment see how it goes then probably go down the r6 route when time & funds allow
