Hey guys, i made the stupid mistake of removing my tank, carbs, airbox, rad etc without photographing my hoses, and my haynes manual is some 300miles away at the moment.
Could anyone provide a diagram/copy of the instructions i need to recconect everything in the correct way?
Cheers!
Thom
Fuel & Coolant hose routing help!
Thom
Re: Fuel & Coolant hose routing help!
mate,
if you hang the rad on first, theres pretty much only one way you can connect the hoses as they are pre-bent.
Try looking under sections 5 and 6 here:
http://www.motomaniac.net/trx850/hosted ... manual.pdf
Shhhh, you didn`t see that here.
