Finally got myself a TRX
- dixonj
After looking for a TRX for nearly two years,driving miles n miles, endless bids on ebay I finally have myself a TRX.
- dixonj
Re: Finally got myself a TRX
yer the one with two pipes yer after. got a txt this morning asking if i was still intrested as the original buyer said that he was unable to collect the bike so drove and done the deal.
Ahaaaa, well done. So that was Burnrubberallday`s bike then?
And YES if you`re ever wanting shot of that unusual exhaust system, get in touch with me first.
- dixonj
Thats the one, gonna be changing the pipes and other bits n bobs dunno what for yet watching some on ebay at the mo, so if i decide to sell i will let you know.
That´s looks very much like an aussie exhaust...asked them and they said one can is a blank...??Mincehead wrote:Ahaaaa, well done. So that was Burnrubberallday`s bike then?
- dixonj
Hi Killerwhale these are 2 into 2, kinda loud just as i like
Nice one!
Thats always been a good looking bike. if it were mine, I'd go back to a fairing and clip-one, but thats all it needs.
And I've seen one set of those cans/exhaust system before, about 4 or 5 years ago....
...maybe this is your bike before all the modifications??
Dave.
Dave.
I got a genuine Yamaha TRX fairing has split on one side easy repair for someone though...in Red / Black.. can take some pics if interested..
Al....
Al....
- dixonj
Went for a good old blast on the bike today, seems to ok but has a bit of a flat spot at 5000 rpm is this the norm for these bikes?. would it be worth having a rolling road session as the bike is fitted with a dynojet kit/ KN filter and modded exhausts.
current settings mains 144
mixture 3 turns
neddle 2nd notch from top
mixture 3 turns
At 5000? No not normal at all, if there`s any carburation problems they are usually lower down the rev range than that. A dyno session, fuel / air ratio check will find the problem no doubt.
NWS870R
I'd say a dyno session is deffo in order. As Mince said a 'flat spot' at 5k would be unusual - it should be pulling hard at these revs. Are you sure you don't mean that the engine is 'bogging down' on roll-on in top gear? Quite a common problem if the jetting isn't set up well - should be easy enough to sort tho
- dixonj
Hi NWS870R yer it is bogging down in 4th n 5th gear when travelling along sitting about 4000 rpm open up the throttle and not a lot happens drop a gear and away we go. was hoping for a bit smoother power delivery. will have to read a bit more on carb setting and have a play.
Bit of carburation fine tuning will umprove it but don`t expect it to roll on like a big multi would, drop an gear and gun it for the instant ooomph.
