Rear Brake Master Cylinder
roymichaeldean
Post by roymichaeldean » Sun Oct 29, 2006 7:23 pm
Hi
My Master Cylinder needs new seals etc...has anyone bounght the Kit...as mentioned in the Haynes handbook....and renovated it
Mmm...the circlip is giving me problems...for a 6 year old bike....these things should be...simple
roy
roymichaeldean
Is there rust in Heaven
Post by roymichaeldean » Wed Nov 01, 2006 6:20 pm
Hi
Still trying to dismantle the Master Cylinder....removed the spring clip....which broke...but there is a plate at the base, which I assume is removable, but it's stuck....rust has kicked in, and its a nightmare to remove...
Anyone else had these enjoyable experiences, and survived ??
Roy
earywig
Post by earywig » Wed Nov 01, 2006 6:58 pm
Hi Roy,
I think you'd be better getting one from Ebay rather than trying to refurb your existing one. Most of them seem to be generic across the Yamaha range anyway. Check with your local Yamaha dealer. I'm down at Flitwick's tomorrow and I'll find out.
Vic
Janitor
Post by Max » Thu Nov 02, 2006 12:05 am
Lots of WD40 and patience... Carefully scrape as much of the corrosion out as you can and maybe try using an air gun to blow the piston and that washer out (just don't point it at anyone, maybe in a box filled with old newspaper...).
roymichaeldean
Looks similar
Post by roymichaeldean » Fri Nov 03, 2006 8:37 am
Hi
Been looking on ebay....and the YZF600 looks similar...so I am bidding on one
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... %3AIT&rd=1
There aren't many around, at the moment
regards
Roy
roymichaeldean
Success
Post by roymichaeldean » Sat Nov 04, 2006 12:30 am
Hi
I have found a TRX replacement for a tenner...which is wonderful....
Should be in my hands in a week.......I know a lot more about Rear Brake Master Cylinders, than I ever knew before Mmmmmm
regards
Roy
