R6 bluespots and master
Post by fung » Mon Dec 05, 2011 10:32 pm
so . . .last saturday the R6 03-04 bluespots went on with an 03-04 R6 master cylinder.
i took some forum advice and fitted up my TRX goodridge lines turning the ends in thru 90deg at the caliper.
much nicer feel than with the std master/blueys combo.
not as hard, more squeeze but very positive.
the trx lines are not really happy with the twist, so i've got some R6 03-04 braided lines coming soon.
pix to follow.
:rr:
Re: R6 bluespots and master
Post by fung » Tue Dec 06, 2011 5:02 am
fung wrote:so . . .last saturday the R6 03-04 bluespots went on with an 03-04 R6 master cylinder.
pix to follow.
:rr:
Post by fung » Tue Dec 06, 2011 5:05 am
pix to follow.
:rr:
Post by cobbadiggabuddyblooo » Mon Dec 12, 2011 11:46 am
Got around to fitting the 14mm Yamaha master I picked up also on the week end.. I feel a lot happier with the wet session upon us with a little more sensitivity in the lever :wink:
M.V.
Post by M.V. » Sat Dec 17, 2011 10:22 am
I did the same thing, but also spun the banjos at the master cylinder end to get rid of the twist, worked well enough.
Post by Mincehead » Sat Dec 17, 2011 10:13 pm
Ah well if you would use the build a line components:
http://www.brakes4u.co.uk/Goodridge_Mot ... ild_a_.asp
as I do you would never have these problems but you are all to worried about your safety to try it. :P
Remeber folks many of the cars you might own and drive have male / female tapered ferrules at any of thie joints.
Alternatively buy lines that can be rotated through 360 degrees because they have spinning collars / swivel nuts:
http://www.venhill.co.uk/Downloads/PowerhosePlus.PDF
http://www.venhill.co.uk/Motorcycle_Hos ... HROME.html
Venhills spoils us in the UK. :wink:
