HI, I got the cleaning up my carbs today and was setting everything to factory settings per the manual but when I got to the needle jets I found something unusual.
The needles are marked 5EI85, which matches up the the manual but the manual says 2/5. Now the needle I have only has 3 slots so I was wondering is this normal, should I set the needles to 2/3??
Needle Jet Question
- Con Rod
Needle Jet Question
- Con Rod
Re: Needle Jet Question
Cheers Phuk, but are you sayinh that 2 of 3 is where it should be or that you would start on 2 of 3 for tuning?phuk72 wrote:Yep - in the middle as a strating point
Does anyone know if the stock needle has 3 or 5 slots?
- fung
are the carbs std BDSTs or import pumpers?
The middle is stock IIRC. Thinking back, pretty sure all had 3 slots not 5.Con Rod wrote:Cheers Phuk, but are you sayinh that 2 of 3 is where it should be or that you would start on 2 of 3 for tuning?phuk72 wrote:Yep - in the middle as a strating point
And by strating in the middle, I mean you can tweak the mixture by raising or lowering the needle a bit if its not right
- Con Rod
They are stockfung wrote:are the carbs std BDSTs or import pumpers?
Looks like the middle then
