YZF 750 swinger
YZF 750 swinger
Hey, what´s the chain slider called in english? Really need a new one!
Anyone actually know where to buy one??
- Con Rod
Re: YZF 750 swinger
good question, in the parts manual for the TRX one it is called "seal, guard" p/n 4NX-22151-00
Re: YZF 750 swinger
`Swingarm chain protector` is what I`ve always referred to them as, seems to suffice. And they are model generic usually, no aftermarket stuff available just, in this case, Yamaha.
I can tell you that the small rubber under the H casting is bl*dy expensive direct from Yamahahahaha, I paid about 20 quid for one!
You can view it on page 37 of 74 of the parts pdf, item 18 referred to as `cxhain protector` part number (4NX-22147-00).
Re: YZF 750 swinger
Nah, i mean this on the YZF750 swinger:Mincehead wrote:`Swingarm chain protector` is what I`ve always referred to them as, seems to suffice. And they are model generic usually, no aftermarket stuff available just, in this case, Yamaha.
Re: YZF 750 swinger
It`s exactly as Con Rod posted Kw, called (by Yamaha) Seal Guard.
Re: YZF 750 swinger
I´m used to find stuff easy on google but this is fekkin hard!!Mincehead wrote:It`s exactly as Con Rod posted Kw, called (by Yamaha) Seal Guard.
Re: YZF 750 swinger
Ahhhh!!
30 SEAL,GUARD
4FM-22151-01-00 1 $66.92 $47.85
nice price only fer me!
30 SEAL,GUARD
Re: YZF 750 swinger
You`ll never get an aftermarket one, it`ll be genuine Yamahahahaha only for parts such as that. No idea what it would be in the UK, is that from Partshark?
Re: YZF 750 swinger
Don´t know...just was glad to finally get a hit on google!Mincehead wrote:You`ll never get an aftermarket one, it`ll be genuine Yamahahahaha only for parts such as that. No idea what it would be in the UK, is that from Partshark?
Here it is:
http://www.mrcycles.com/fiche_section_d ... 6&fveh=722
Re: YZF 750 swinger
You need 4NX as the prefix to be sure it`s the right one, Yamaha might use the number section (22151) for other models like the last section too -00 is what you need not -01
Edit:
Boll*cks disregard everything I just said, I`m looking at the stock TRX swingarm not a YZF750! Doh
Edit:
Re: YZF 750 swinger
Doh indeed!!Mincehead wrote:You need 4NX as the prefix to be sure it`s the right one, Yamaha might use the number section (22151) for other models like the last section too -00 is what you need not -01
Edit:
Re: YZF 750 swinger
Re: YZF 750 swinger
cheersMincehead wrote:Hey Kw, even cheaper at Partshark:
http://www.partshark.com/fiche_select.a ... 2151-01-00
4 sure beats the 120£ i found it for in Sweden!!
Re: YZF 750 swinger
£28.33 UK, I reckon that`s a good price but there will be p&p from the States to consider too.
Re: YZF 750 swinger
And possible import tax...Mincehead wrote:£28.33 UK, I reckon that`s a good price but there will be p&p from the States to consider too.
