After putting the 900 lump in the trix and doing one a bit faster run in about 17 degrees i noticed it actually runs warmer than the TRX878cc wich in turn ran a lot hotter than standard due to comp and bore.
Have you guy´s with both machine´s noticed any difference in temp on the bikes?
Q for those with both TDM/TRX
- fung
Re: Q for those with both TDM/TRX
my 9er runs hotter than the trx.
I was guessing the smaller has between cylinders or the smaller radiator could be the culprit.
Not so sure now you say yours is a bit toasty.
878s have less between the bores too eh.
Fung
Fung
At least less wall between combustion and waterchannels....fung wrote:my 9er runs hotter than the trx.
Fung
Good to know though you 9er is hotter, is it the same type thermostat and placed the same on 9er?
