Oil pump cover
Kenvis Repesco
Oil pump cover
I am going to take the oil pump cover off to spray it. Could you tell me if I have to drain the oil before I remove it. Or is there anything I should know before I take it off...thanks David.
- fung
Re: Oil pump cover
perhaps combine an oil change with this and use a new gasket in the install of the cover,
