drix
by drix » Tue May 01, 2012 12:31 pm
Hi
I ran a search for a question I had but I am a little clueless as to what it could be under/search for.
Since the rebuild of my TRX, I changed a few things and now for some reason, I can no longer restart the engine if I stall when in a gear and pulling the clutch lever. Not that it's a major problem but since I do a lot of town riding in central London & suburbs, I am perhaps more prone to stalling if I don't pay enough attention when taking off at the traffic lights... having to find neutral in order to restart the engine in those moments might create a tricky situation.
I am sure I was able to this before and the only thing I can think off that is causing this issue is the fact that I recently fitted some shorty levers and to do so, had to fit an early R6 clutch clamp/perch. This means I am not able to reconnect some cables that where connected to the TRX clutch clamp/perch. Is that the source of the issue and what can I do to by pass this? Or is the issue from elswhere/what should I check?
Adrien
drix on Tue May 01, 2012 4:15 pm, edited 1 time in total.
by Killerwhale » Tue May 01, 2012 12:44 pm
drix wrote:Hi
I am sure I was able to this before and the only thing I can off that is causing this issue is the fact that I recently fitted some shorty levers and to do so, had to fit an early R6 clutch clamp/perch. This means I am not able to reconnect some cables that where connected to the TRX clutch clamp/perch. Is that the source of the issue and what can I do to by pass this? Or is the issue from elswhere/what should I check?
Adrien
Short the clutch contact(or check/replace), i had to when installing the ISR´s.
by Mincehead » Tue May 01, 2012 12:48 pm
Yep a switch at the lever is what you require, one that makes contact when you pull in the lever. You could of course do away with it altogether like I have.
I always know when I`m in gear and when my sidestand is down irrespective of idiot lights, I hate `safety` gadgets on bikes that effectively allow the riders to become dullards.
drix
by drix » Tue May 01, 2012 1:45 pm
OK, so I suppose I can just cut the connector and join the two cables (+ & -) together? (I am a bit clueless when it comes to electrics
by Con Rod » Tue May 01, 2012 2:03 pm
Yup, you can test between the + and - with a paper clip first
cal
by cal » Tue May 01, 2012 3:14 pm
yup, two small spade type connectors (halfords or similar?) at either end of a small bit of wire, push these into the existing clutch switch wires, wrap it up with a bit of black tape and that should sort it out, also giving you the option to return to standard should it be required,
Cal
drix
by drix » Tue May 01, 2012 4:16 pm
Great stuff, I'll add this to my list of "little" things to finish off
