Overbore on black motor = no go?
redkiwi
Post by redkiwi » Sun May 06, 2012 12:22 pm
I've got a lead on some Arias pistons to replace my shot Wossner items which were standard bore but high comp. The Arias pistons are 868cc so I need to do an overbore but I've been told that the black motors aren't good for overbore. Is this true? If so, can I fit the silver motor barrels/head or do I need to find myself a complete silver motor?
Re: Overbore on black motor = no go?
Post by Killerwhale » Sun May 06, 2012 12:30 pm
redkiwi wrote:I've got a lead on some Arias pistons to replace my shot Wossner items which were standard bore but high comp. The Arias pistons are 868cc so I need to do an overbore but I've been told that the black motors aren't good for overbore. Is this true? If so, can I fit the silver motor barrels/head or do I need to find myself a complete silver motor?
I would be very surprised if the specification differs, what is the source of this info?
redkiwi
Post by redkiwi » Sun May 06, 2012 12:54 pm
The guy with the pistons. Used to have an OV15A customer bike
redkiwi
Post by redkiwi » Sun May 06, 2012 1:53 pm
These are the two sets of pistons :shock:
Post by phuk72 » Sun May 06, 2012 3:25 pm
Black engines are perfectly capable of being over bored without any issues. Anyone who tells you different is wrong!
Honks motor was a 'black' and that was taken out 2mm overbore
Post by trixynut » Sun May 06, 2012 6:25 pm
Can the motor go to 868 and still retain enough metal between cylinder and water jacket??
NWS870R
Post by NWS870R » Sun May 06, 2012 7:57 pm
Yes, 868 is max bore available direct from Yamaha. JE pistons are larger bore & can be run with no issues.
I've never heard any issues over boring black engines - sounds like a ridiculous bit of advice to me
redkiwi
Post by redkiwi » Mon May 07, 2012 12:33 am
Cheers, guys I think thats enough to let me know that I'm safe to go ahead :D
I'll let the guy know he was misinformed. He's got a six speed gearbox setup there too, what do you guys reckon it is worth? It's all new, still in packaging. A 260kph top speed is rather inticing for the tracks I'll be running the bike on.
Post by cobbadiggabuddyblooo » Mon May 07, 2012 11:33 am
check out Kedo.com for 878 piston kits.(249pounds x2) around $700 aust for both pistons. They have oversize head gaskets to suit also. Cheap base gasket/valve seals etc and postage
Tesa
Post by Tesa » Mon May 07, 2012 12:27 pm
I will personally prefer to order it from TTS performance - it costed me 388 pounds posted (pistons + head gasket).
Regards
Radek
Post by Mincehead » Mon May 07, 2012 5:08 pm
redkiwi wrote:These are the two sets of pistons :shock:
Feck a rook, look at those valve cut-outs, what compression ratio are those Arias meant to give redkiwi? :shock:
redkiwi
Post by redkiwi » Tue May 08, 2012 2:07 am
All he said was that one set was "high compression" at around 12:1 and the others are "yeah, higher compression"
Post by Mincehead » Tue May 08, 2012 7:38 am
I`m guessing around 13.5 looking at those crowns and valve cut outs, FECK, pump fuel will struggle at that!
If they are direct copies of those fitted in the OV15A they should be 12.8 to 1. Best you find out in advance of using them. :wink:
Post by cobbadiggabuddyblooo » Tue May 08, 2012 7:47 am
Tesa wrote:I will personally prefer to order it from TTS performance - it costed me 388 pounds posted (pistons + head gasket).
Regards
Radek
Bingo :) :) glad I haven't ordered yet
Post by Mincehead » Tue May 08, 2012 8:00 am
redkiwi wrote:Cheers, guys I think thats enough to let me know that I'm safe to go ahead :D
I`m intruiged, one of Over`s 6 speed creations redkiwi?
Would be likely to have been at least 1,500 English quids worth if it is truly Over stuff, oh and a top whack of 160 mph for a TRX? Even a higher final drive ratio and tuned one might hit that on the 5 speed box.
According to the calculations a 17 / 33 sprocket arrangement might see you achieve it but don`t expect a clutch to cope with the racing starts on that gearing!
