TDM Large bore Headers
Gix
Anyone know if the tdm 850 headers will fit a trx?
I've managed to drop on some aftermarket large bore headers with a single outlet large bore link pipe very cheap.
I know the motors are the same but I don't know if TDM's have a different set up under the motor
Re: TDM Large bore Headers
Motors mount different in the frame so check the search..
ssray
Are they micron ones?Did you out bid me on evil bay? if so they wont fit and i`ll give you a fiver?
I was looking at trying to get some 900 or trx ones to and try them on my 1994 3dv tdm850, but it appears the engines are at diffrent angles- and 900 ones are quite rare and a bit pricy to mess with.
I did look at buying some bends and having headers welded, but no time.
Ray
Ray
TDM pipes wont fit a TRX as the TDM motor is tilted further forward in the frame than the TRX.
GrazyChris
ill see your trxhool and raise it ..trx tuono
Gix
doesnt allow for search..its just a pic.GrazyChris wrote:Have alook here
http://i184.photobucket.com/albums/x4/t ... C02233.jpg
and search for trxhool
That swinger looks massively long though.
Are you showing me TDM headers or something ?
I now have the headers here and after a quick size up I cannot see why they can't go on..time will tell
GrazyChris
only of course of the TDM-headers
I have a TDM900 engine with pipes - I will let you know if the headers fit the trx chassis.
