Six pot calipers for TRX
Homer
Post by Homer » Fri May 25, 2012 11:39 am
Anyone know if any of the Yamaha 6 pot calipers will fit the TRX???? And is it worth doing compared to blue or gold spots? Running single disc front end and looking for a bit more stopping power.
Re: Six pot calipers for TRX
Post by alextrx850 » Fri May 25, 2012 11:45 am
im sure that the six potters [much different to the harry potter]...are the same bolt spaceing as ive had the old trx calipers on my yzf 750 front and also had the six pot calipers as well
therefore the trx at least will fit on i guess
want a set..?
Homer
Post by Homer » Fri May 25, 2012 11:58 am
How did you find the 6 potters compared to the TRX calipers, and how much do you want for them?
Post by Con Rod » Fri May 25, 2012 12:35 pm
No experience myself but from what I have read in mags etc the 6 pots on the yzf750 etc performed well but where prone to seizeure and required a reasonable amount of preventative maintainence. When the blue spots came along they were something of a revaluation in that they performed just as well or perhaps even better than the 6 pots and had none of the reliability issues
cal
Post by cal » Fri May 25, 2012 1:54 pm
I think the six pot and the blue spot are roughly the same in terms of stopping power from what I have read on the forums so far, the main difference being the sixpots are designed around a 320mm disc and the trx is 300
I suppose the thing to note is that most folks seem to be doing the bluespot conversion to the yzf forks which would suggest the bluespots are better. I think there is less maintenance to do on the bluespots also.
Cal
Post by dixonj » Fri May 25, 2012 3:28 pm
Hi,if it helps any I had 6 pot calipers and changed to gold spots with a 14 mm master cylinder feels loads better now.
cal
Post by cal » Fri May 25, 2012 9:50 pm
going a bit off topic here but did you try the six pot and 14mm combo? I have this on the bike now but not got it finished yet, so havnt tried it on the road, but,... the lever feels as though there will be a lot of control and plenty power there.
Cal
Yami
Post by Yami » Wed May 30, 2012 2:18 pm
Bit late perhaps, but I can confirm that YZF six pots will fit the TRX´s bolt pattern.
TRX, YZF750, YZF1000, R1 (at least 00-01) have the same bolt pattern. :)
Post by Tarwetijger » Thu May 31, 2012 11:17 am
They will fit indeed but the brake pads take a smaller part of the disc (because they are ment for 320mm discs).
I 've had 6-pots on my TRX (original forks, 300 mm discs) and didn't like it at all. Stopping power isn't bad but in all honestly I have never felt a bike with firm brake handle feeling if 6-pots were fitted (YZF750R or TRX). To revise the 6-pots costs a small fortune, hence the massive swap to bluespots.
The bluespots also use the whole disc, as it should be.
