Hi!
On my first TRX a "mechanic" adjusted the valves and tightened the cam screws to much - so the crank shaft died.
Then he bought a (cheap) TDM cylinder head, swapped the cam shafts and assembled the engine again - only to notice only
then that this mentioned mounting hole was missing.
So I saw this with my own eyes.
Maybe only the 3VD cylinder head was without this mounting hole and the later TDM models cylinder head were the same as the TRX one?
@sanddune51
sanddune51 wrote:My TDM is an early Mk1 (91-96 360/180 degree engine) that has been extensively modified
Hmmm "extensively modified" ... maybe with a TRX or later model TDM cylinder head?
@dandywarhol:
TRX engine in a TDM is ok but
TDM engine in TRX will disclose the missing mounting hole (at least if it's a 3VD).
Witnessed greetings from Munich!
TRX 850 & Racetrack-TRiXie
