hi guys can anyone tell me which kawasaki rear shock will fit my baby, as mine is shot, also which is the best way to go, kawasaki or r6 shock.
thanks dave
rear shock
Re: rear shock
The R6 seems to have been adopted the most Radman..you must have the tuneing fork lower link to be fitted with one of Kaylas adapters...just type r6 shock into the [SEARCH] tool bar at the top of the page...you will be so enlightened my sonradman wrote:hi guys can anyone tell me which kawasaki rear shock will fit my baby, as mine is shot, also which is the best way to go, kawasaki or r6 shock.
thanks dave
- drix
Re: rear shock
I have an 04/05 (I think) ZX10 rear shock... just need to drill out one of the lower holes to 12mm, no Kayla adapter required. Bear in mind that this shock is shorter than standard so will lower the rear end... shorter dog bones will solve this!
The R6 shock + adapter is the more common mod though so it's up to you really.
Hope this helps.
*edit: 2001 GSXR1000 also fits
Hope this helps.
radman
Re: rear shock
hi alex and drix i would like to thank you both for your help and i think i will go with the r6 shock
thanks again dave
thanks again dave
- dixonj
Re: rear shock
2006/2007 zx10r shock fits also zx6r fits, this is a little softer sprung.
