Chain length
bubbaad
Chain length
Post by bubbaad » Sat Aug 25, 2012 9:45 pm
I have had a search and it seems that a 110 link chain is the way to go with a 42t sprocket.....Can anybody confirm this ?
I fitted the sprocket and under the advice of the chain supplier I purchased a 114 link chain....ha ha ha, way too long. I don't have the tools to shorten it so I deffo need the correct length.....It will be fitted with a split link. Am well p*ssed off as I can't use the bike this weekend. Cheers in advance.
Kevtrx849
Moderator
Re: Chain length
Post by Kevtrx849 » Sat Aug 25, 2012 10:50 pm
Yup, 110 links is correct. You need a grinder to take the top off the pins to shorten it or a chain breaker. Can be done with a file and a vice as well.
( HENRY FORD )
bubbaad
Re: Chain length
Post by bubbaad » Sat Aug 25, 2012 11:05 pm
Thanks, Will get the grinder out tomorrow..... :)
Wombat
Forum Marsupial
Re: Chain length
Post by Wombat » Sun Aug 26, 2012 2:07 am
I run 17t/42t and 110 link chain so it fits perfectly.
bubbaad
Re: Chain length
Post by bubbaad » Sun Aug 26, 2012 5:56 pm
Done.....Thanks guys
