Rear brake caliper
gretch1
Rear brake caliper
The rear brake caliper on my bike is funked. Ebay prices are quite high for TRX parts. Are there any other yamaha calipers that bolt straight on?
- Con Rod
Re: Rear brake caliper
YZF750 is a straight swap. I would imagine the YZF600 Thundercat the YZF1000 Thunderace are also a straight swap but can only confirm the YZF750
gretch1
Cheers, I'm just off to the breakers for a Thunderace caliper. I'll let you know if it fits.
Gretch
Gretch
I have a rear caliper you can have cheap if you want it.
Only thing is I have never used it as I took it off the bike as soon as I bought it so have no idea whether its any good or not.
I have no reason to think its knackered however.
gretch1
Just fitted a 2nd hand YZF Thunderace caliper - no problems. Thanks
- Wombat
- Forum Marsupial
XJR1300 ones fit as well
